Farmall H at work
don g
11-18-2007 15:10:41
third party image
Nothing better than having a neighbor with a stump grinder and some time on his hands.It took an hour for the stump but an hour and a half for the beer.Life is good
LenNH
11-26-2007 06:55:10
 Re: Farmall H at work in reply to don g, 11-18-2007 15:10:41
Another quick comment. Most of the tractors sold in the 20s and 30s on steel have been converted to rubber, just like this H. On original Farmall and F-20, the only way to keep the "narrow" setting of the wheels was to use 36" rims to replace the 40" steel wheels. The result was a tire that was much larger in diameter than the steel wheel. Speeds in each gear went up a lot.
Some F-20s (and -30s, too, I guess) had a smaller tire, but the rims had to be turned OUT permanently. VERY wide tractor, but the speeds would have been closer to original.
One problem with these converted wheels is that they are light. IH and others tried to add some weight to the rears by using a cast wheel on the F-12/14 and H and M. There were additional axle-mounted weights available, too, as I recall. I vividly remember an F-20 I used to use that would slip a lot in heavy plowing--no water in tires, and no weights added to the wheels.
LenNH
11-19-2007 10:31:00
The flat, thin spokes are cut-offs from steel wheels. WW II cut off a lot of rubber availble for tires, and tractor mfrs. were forced to go back to steel for a while. On H and M, fifth "gear" (just a dog-clutch that moved forward and connected input to output shafts) was locked out with a bolt that went down in front of the shifter rail. Of course, you could "install" fifth gear after conversion to rubber--just turn the bolt up a bit, or replace it with a short one. I've often wondered if any dealers offered to "install" a road gear and charged much for it.
Pat-CT
11-18-2007 20:05:30
what is that a 9 speed or a hand clutch
don g
11-19-2007 04:07:02
 Re: Farmall H at work in reply to Pat-CT, 11-18-2007 20:05:30
I am embarrased to say i dont know what the ectra shifter knob is for.I did not notice it when we were working and was first time i had ever seen his tractor.I promise i will find out for you and repost the pic.It also has the best looking 3 point on it i have ever seen.He did tell he bought it thru red power mag.
GP
11-19-2007 12:18:39
 Re: Farmall H at work in reply to don g, 11-19-2007 04:07:02
I believe that is an add-on lever to be able to engage the PTO using your right hand without bending over to use the original lever.
Wardner
11-18-2007 18:29:28
Does it have a nine speed? I see two shifter knobs.
City-Boy McCoy
11-18-2007 17:40:40
My, what a nice, nice H. I wish my super H looked that good. Beautiful photo of a pretty tractor. mike durhan
Mike CA
11-18-2007 17:04:51
That is a great lookin' H!
Andy Motteberg
11-18-2007 16:00:33
Hi Don, That is a very nice looking H! What year is it? I've got a 1943 H that I restored a short time ago. Mine has the same McCormick Deering Farmall decals, same front wheels and same style rear wheels as yours. My rear wheels are the heavy cast iron ones, not the thinner pressed steel ones. I'm going to show some pictures of my 1943 H tonight, I'm uploading them all into an online album with my SLOW dial up connection. My H has a belt pulley too. I want to get fenders for mine someday. You have a real nice H!
Andy.
don g
11-18-2007 16:54:15
 Re: Farmall H at work in reply to Andy Motteberg, 11-18-2007 16:00:33
It is a 1940.I wish i could claim it but its really his tractor.I own a restored super c and it sits right next to the beer fridge in the shed.Great thinking on my part eh?
Lloyd1
11-19-2007 07:21:01
 Re: Farmall H at work in reply to don g, 11-18-2007 16:54:15
I think the best reason to park the C next to the frige is to grab a second beer on the way bye....
Damp;Dservice
11-18-2007 15:11:44
VERY NICE! thats a good lookin H, I have never seen the Mc cormick deering decals, What years were those used?
CNKS
11-18-2007 17:27:57
 Re: Farmall H at work in reply to Damp;Dservice, 11-18-2007 15:11:44
1945 is when the letter series stopped using the McCormick Deering decals without the IH, prior to that they read McCormick Deering Farmall, as in the picture. From about that time until mid 1949 they read IH McCormick Deering Farmall. In mid 1949 the Deering was dropped and they read IH McCormick Farmall. The 1947 Cub should read IH McCormick Deering Farmall Cub. The last of the Super letter series, the Super H did not appear until 1953.
Andrew Z
11-18-2007 15:35:30
They used them from 39 till 45 in that time frame. dont have a book on hand but thats when i belive when the letter seires stoped, and the cub used that till mid 49
Andrew
David Goode
11-18-2007 17:03:02
 Re: Farmall H at work in reply to Andrew Z, 11-18-2007 15:35:30
The letter series went from 1939 to 1955. With the introduction of the Super Series in 1948 and 1952. I think the Cub used that same decal only in it's first year of production. -David Goode Coggon, IA
