draining coolant water W9
railhead
11-20-2007 16:13:52
Will removing the bottom radiator hose on W9 drain the engine block as well as radiator? Getting cold tonight and I just tested coolant in my 9 I bought this spring to find out it is mostly water. Thanks.
markloff
11-20-2007 23:18:31
 Re: draining coolant water W9 in reply to railhead, 11-20-2007 16:13:52
There should be a drain right in front of the lower radiator hose at the bottom of the radiator (there is a hole on the front end casting to access it) and (at least on my two SWD9's) on the left side of the block middle lower. Hope this helps.
Mark
Steven f/AZ
11-20-2007 19:23:51
Carburetor side has a drain plug.
railhead
11-20-2007 20:04:55
 Re: draining coolant water W9 in reply to Steven f/AZ, 11-20-2007 19:23:51
It is propane and just south and in front of the carb the regulator is plumbed into the block. I did pull the hose off that and about a gallon drained out...is that the only drain? I cannot find anymore orifices into the block.
Roger in Iowa
11-20-2007 16:40:13
No! You have to remove or open a drain on the side of the block as well.
Roger in Iowa
railhead
11-20-2007 19:14:52
 Re: draining coolant water W9 in reply to Roger in Iowa, 11-20-2007 16:40:13
which side? where? I gotta drain her, HARD freeze coming in tomorow night. THANKS
