pto adaptor
tn terry t
11-22-2007 07:44:37
does anyone make an slip on adaptor to change from 1 1/8 to 1 3/8 pto shaft for an A farmall
Dairy farmer in WI
11-23-2007 08:39:43
 Re: pto adaptor in reply to tn terry t, 11-22-2007 07:44:37
yeah. i don't remember the MFG name but i got one for $30 at the nearest salvage yard. that was a litle high though
DF in WI
gene bender
11-22-2007 08:57:33
You dont need an overunning assy with a sickle mower. If you need an adapter i have some for free just semd enough for postage.
old
11-22-2007 08:28:47
Any good farm/home place will have them. One problem is you need to use a pin or bolt to hold the adaptor and PTO shaft on with them. What might be better but cost a good bit more is putting on a ORC which is also the safe way to do it because the A doesn't have live PTO and most PTO drive equipment will try to push you when you push in the clutch pedal
steve from mo - dangit!
11-22-2007 07:57:09
Those are pretty common since the Ford N's and older JD B's had 1 1/8 PTO as well. Try your TSC store.
tn terry t
11-22-2007 08:50:29
 Re: pto adaptor in reply to steve from mo - dangit!, 11-22-2007 07:57:09
the only reason i need is because im mounting a cycle bar mower on it it come off an super A the pulley i have is for 1 3/8 i wonder if i might run up on a pulley that is 1 1/8 thanks guys
