Order Farmall Cub Parts Online
Cub clutch release bearing
oldiron29
11-22-2007 15:07:53
I redid my cub 3 years ago. In the last year my clutch started to chatter. The peddle got so bad that I parked it and split it. The new bearing I put in was the roller type it came with carrier, its worn right down. I ordered a new graffite one, don't have it yet. Will the graffite one come with new carrier? Or do I have to put it in the old carrier? How do you get the bearing out of the carrier and the new one in? oldiron29
oldiron29
11-22-2007 15:46:20
 Re: Cub clutch release bearing in reply to oldiron29, 11-22-2007 15:07:53
Ron, Thanks I looked at all the pros and cons.
Last time I tought the roller type would be better. But after hearing all the feed back most guys like the old graffite ones better. Thats what my cub had in it when I pulled it down. I should have left it in and I probably would not be in it this time. Thanks again oldiron29
