450 hydro pump leaking
Bill thompson
11-23-2007 05:04:29
My 450 hydro pump is leaking where the two metal lines come in at the bottom of the pump. Is there a gasket in there? It looks like its metal to metal. Thanks Bill
glennster
11-23-2007 05:47:22
 Re: 450 hydro pump leaking in reply to Bill thompson, 11-23-2007 05:04:29
the two lines screw in to a little metal plate at the bottom of the pump. the metal plate then bolts to the pump. there are 2 orings between the plate and the pump. if the hoses are not leaking where they go into the plate, remove the bolts, drop the plate down and replace the o-rings. napa should be able to match them up.
