H Needs new gear
JJ in MI
11-23-2007 13:48:43
I need to replace 2nd gear in my 1950 H. Can this be done by removing the gear plate cover only or will I have to split the tractor in half?
I know it will be a big project, figured I better ask this question before I tear into it. Thanks guys
JJ in MI
11-26-2007 08:41:29
 Re: H Needs new gear in reply to JJ in MI, 11-23-2007 13:48:43
Thanks guys, I appreciate the advice. I will be needing the gear, but I want to get in there and get a complete idea of what I need. Thanks for the offer, I will check back with yall once I open her up. thanks again!
Bob Kerr
11-23-2007 16:14:34
While you are in there check those bearings out. That is the time to do replacing if need be. Also better change the lower gear. Get them in the set that they ran with otherwise you will get noise. Get bearings and seals at a bearing house and it will save you a TON of $$$. I got my gaskets from CaseIH.
Nebraska Kirk
11-23-2007 14:16:18
Like Terry said, you don"t have to split the tractor, just remove the top to the tranny/rearend. You will have to remove the belly pump too and disconect the input shaft. Do you need a replacement gear? I have a spare 2nd/3rd slider gear and I might have the gear for the bottom shaft too.
tn terry t
11-23-2007 13:58:07
no need to split the tractor you can conpletly gut the transmission by removing the top but let me warn ya that top aint lite dont try it yourself unless you have a lift
