Super H Compression
Matt Weltz
11-24-2007 12:03:33
Hey guys! Just bought a '53 Stage I SH and was wondering about what the compression should be. I just got done checking it and it holds 100lbs. on every cylinder. Engine has never been rebuilt to my knowledge. It does not knock or smoke so I am thinking I won't waste my monye on rebuilding the motor. What do you guys think?
Janicholson
11-24-2007 17:56:14
 Re: Super H Compression in reply to Matt Weltz, 11-24-2007 12:03:33
Be sure the throttle was wide open when checking it, and also check the accuracy of the gauge. They go out of calibration. If it is running sweet, run it. JimN
pat in wis
11-24-2007 15:36:37
Did you get SH 8729 J ? Would like to know when you get a chance if the engine serial number is around 10190 or a little less. Again, I hope you enjoy the tractor as much as I like my Super H.
Pat in Wis
Andy Martin
11-24-2007 12:24:38
I think I would not have done a compression test if it did not knock or smoke.
I work my tractors and they only go to the clinic when they are sick.
pat in wis
11-24-2007 12:15:14
sounds like you got a good one, as long as all cylinders are about equal I wouldn"t worry about 100 psi. hope you enjoy your Super H.
Pat in Wis
