Farmall Rear wheel bolts
Jay Snyder
11-24-2007 15:57:14
Hello I am wondering what the best way to remove the rear rim bolts out of the hub I purcashed a new set of rear rims and they are wider than the origanals were (in the center drop) so I need to put longer bolts in could anyone help as to the best way to remove them. Thanks
Hugh MacKay
11-24-2007 16:24:45
 Re: Farmall Rear wheel bolts in reply to Jay Snyder, 11-24-2007 15:57:14
Jay: What model tractor, and which type of wheels. These change quite a bit near the introduction of Supers. Sounds like your talking H or M, however if it's C, SC, 200, etc. it's another matter. Same with offsets, different again.
Come back with at least model, and better if you can fully describe wheels.
Jay Snyder
12-29-2007 18:16:31
 Re: Farmall Rear wheel bolts in reply to Hugh MacKay, 11-24-2007 16:24:45
It is on a 1951 Farmall MD the origanal wheels were in very bad shape and I brought new rims but the center hump is deeper than the origanal by about a half inch so I need to change the bolts that hold the wheel dogs or locks on the hub. Thanks
