Farmall A, Oil in Anifreeze??
Tom Stein
11-24-2007 16:04:37
My Farmall A runs great, burns a little oil. My question is why do I see oil in the antifreeze? No antifreeze in the oil that I can easily see.
Is this a head gasket problem or more serious like leaking sleeve seals? Any ideas??
Andrew Z
11-24-2007 17:02:58
 Re: Farmall A, Oil in Anifreeze?? in reply to Tom Stein, 11-24-2007 16:04:37
You got it right there start with the head gasket hopefuly that the answer. If with the oil pan removed check to see if you can see rust stains down the sleeves then it would have to be O ring seals on the sleeves. if not that then possible cracked sleeve or block. also might be a bad frezze plug in the head? just a thought also.
Andrew
