ATTN: ENGINE BUILDERS! Red Power 140 Pistons, 2nd time aroun
scott#2
11-24-2007 18:33:56
third party image
Just thought I would let every one see the difference in the original pistone and the replacement set after I complained about the wrist pin hole being bored crooked. Notice the difference in the casting marks. I suspect they had a bad run and tried to pawn the reject set off on me. Fat chance of that happening. Next post is a pic of the new set.
scott#2
Steven f/AZ
11-25-2007 14:28:33
 Re: ATTN: ENGINE BUILDERS! Red Power 140 Pistons, 2nd time a in reply to scott#2, 11-24-2007 18:33:56
Mine had sharp edges on the built up parts... I filed them down smooth so there wouldn't be any hot spots to start the piston to melting... Keep us updated on your new set.
Steven f/AZ
11-25-2007 10:51:25
Are those Conformatic pistons? They look similar to the ones I put in my H:
third party image
scott#2
11-25-2007 11:03:38
 Re: ATTN: ENGINE BUILDERS! Red Power 140 Pistons, 2nd time a in reply to Steven f/AZ, 11-25-2007 10:51:25
I dont have the new ones in my hands yet. Sure do look the same though, right down to the round release mark in your insert pic. The bad set I had, had Clevite on them I am anxious to see where the new ones came from.
scott#2
Brian Schmidt
11-24-2007 21:30:19
I didn't completely follow your post last time. Did you fit the head on to check for clearance issues? Yea that are not correct, but would they have worked? I wonder because I have given thought to buying the Red Power kits and want to know what to expect.
Thanks!!
scott#2
11-25-2007 10:40:59
 Re: ATTN: ENGINE BUILDERS! Red Power 140 Pistons, 2nd time a in reply to Brian Schmidt, 11-24-2007 21:30:19
Brian,
I havent tried a trial assembly yet, I'll just do the old clay trick to make sure domes dont hit and valves dont hit the domes, etc. I called Case and they get 250$ per hole, pist, pin, clips, rings, cylinders, no o rings. Pure insanity. I would say that Red Power kits are "ok", not great though. Check and double check everything. I found some chaff on one of the main bearings oil holes that needed to be cut off. No doubt it would have come off at some point when the engine was running and scored that main set up. CHECK AND DOUBLE CHECK ALL ENGINE COMPONETS.
scott#2
scott
