H is difficult to start
Illinois Farmal
11-25-2007 09:01:45
Lately I have been having a difficult time starting my H. The starter on it turns over very slow and sometimes not at all. Sometimes after several hits on the starter button it will spin over. I replaced the battery thinking that was the problem but no improvement. It is an original 6 volt system and it has the heavy duty cables. Could this be a bad starter causing this problem? Thanks.
teddy52food
11-25-2007 14:43:19
 Re: H is difficult to start in reply to Illinois Farmall, 11-25-2007 09:01:45
Anytime you suspect a bad cable, just use a good heavy booster cable and jump the bad one. If it turns better you know the cable is bad. Check them all , there may be more than one.
jps
11-25-2007 14:39:37
I'll have to tell you about "H" in our family. My Dad had this tractor for years. It finally came to our house, father passed away! This H always did just what you are describing. Started had been taken apart and check severall times over the years. Still started hard. I finally removed starter, went starter shop, this guy checked the heavy brass bands around the starter case. Not sure what they are called. One band had a crack, soldered it, never started so good. I couldn't believe we had put up with this starter for so many years!! Godd luck with your "H". jps
gene bender
11-25-2007 13:27:39
Take the ccover off the starter tha covers the brushes you will probably the problem. Starter need good rebuild or even reolacing. You can get a new one for 115 pluss shipping.
old
11-25-2007 09:37:33
Most likely the starter button is going bad. The contects inside of the switch over the years get burned and because of that they start doing what yours is doing.
Steven f/AZ
11-25-2007 09:18:06
If you are having to push the starter button several times to get it to "catch" I would suspect a bad starter button.
You can always (very carefully, make sure it is in neutral) jump direct from the battery to the starter to see if the starter is good. This is best to try with a friend sitting on the tractor and holding the clutch in as well as having it in nuetral.
Illinois Farmall
11-25-2007 10:50:36
 Re: H is difficult to start in reply to Steven f/AZ, 11-25-2007 09:18:06
The starter will "catch" when the button is pushed....just won't always turn over or when it does it'll turn over maybe once.
CNKS
11-25-2007 09:16:27
It could be the starter, but first take the cables off and clean them -- all connections, at the battery, starter button, ground, etc. Also check for corrosion INSIDE the covering on the cables. That has been my problem a couple of times, even with a 12 volt system. Cleanliness and good connections are more important than cable size.
