Is it a leak or a weep hole - Farmall H
Jim Isler
11-25-2007 13:39:17
The lower (radiator outlet) pipe has a 1/8 hole at the exact center of the lower bend, right where the hose clamp goes. It is so close to round that I can't tell if it's supposed to be there or has just worn thru. I can have it brazed easily enough, but if it has some purpose I guess I can leave it.
Advice?
CNKS
11-25-2007 14:21:38
 Re: Is it a leak or a weep hole - Farmall H in reply to Jim Isler, 11-25-2007 13:39:17
It's not a weep hole, likley corrosion finally got to it.
