Started 450D Ran Good Then???
eric and his fa
11-25-2007 14:16:12
Hey Guys Hopin You Can help Me On This One Just Got my 450d Finally Home Never Heard It run Guy I Bought It from Said It Ran Good And had Some Bio Diesel In It Dumped Some Seafoam in The Tank And Gave It a Shot of some starting Fluid And She took off and seem To Run Good Drove it around For approx 20 minutes then it went to Running Wild Stopped It Quick But what you think would cause it to Run Wild??
MN Scott
11-25-2007 15:36:48
 Re: Started 450D Ran Good Then??? in reply to eric and his farmall 450d, 11-25-2007 14:16:12
The racks in the injection pumps are prone to sticking wide open on those pumps if they have'nt run in some time. Someone will be along with the procedure to free it up.
Janicholson
11-25-2007 14:57:38
Several things can do it. Too much Sea Foam? How much in the amount of Diesel in the taank?
Stuck governor. Possible adjustment of the intake manifold for the gasoline fuel system, allowing gasoline mix into the system.
Very light oil in the aircleaner being sucked into the intake. Telll us more. JimN
11-25-2007 16:29:02
 Re: Started 450D Ran Good Then??? in reply to Janicholson, 11-25-2007 14:57:38
Here Is what I Know Tractor Had Oil Changed Not Sure Bout Air cleaner Oil Has Bout Half Tank Believe to Be Bio Diesel Dumped One Can Sea Foam In It Warmed Tractor With Block Heater For At Least A Hour Hooked Cahin Up Towed it Down Road Gave it a Shot of starting Fluid Fired up Was Runnign Fairly good some popping like it wasnt warmed up drove it down road for at least ten minutes or so had it in the yard running half throttle all of a sudden it took off wild till we shut it down real quick is something stuck in the injection pump? it ran good till we opened the shut off of the starting tank and has gas goin down to carburetor any help be great thanks guys
AJB450
11-25-2007 21:47:19
 Re: Started 450D Ran Good Then??? in reply to eric and his farmall 450d, 11-25-2007 16:29:02
Eric, My 450-D did something similar once. After starting it and switching it to diesel, it started to run fast and ping badly. I suspected the carburetor float stuck. Shut the gas valve off on the tank and it ran fine on diesel. Tapped on the carburetor, turned the gas back on and no problem with it for the last two years. I suspect that if the float sticks, gas vapor can still get into the combustion chamber and cause this problem or maybe if the butterfly in the intack manifold doesn't close tight, gas vapor can get in when running on diesel side. Anyhow, since you say this problem started when you opened the gas valve, I would check these two items.
