350 Power Steering
Salty
11-25-2007 14:19:54
Am trying to add power steering on a 350 Farmall. Got all the components from a salvage yard including Behlen unit, safety/priority valve, and left most hydraulic control valve. Fired unit up and only have power steering when I move one of the control valves forward or backward against plugged lines. Anyone have any thoughts as to what my problem might be?
randy hall
11-25-2007 19:08:35
 Re: 350 Power Steering in reply to Salty, 11-25-2007 14:19:54
dave slater to the rescue again. you guys should send him a dollar every time he helps you.
D Slater
11-25-2007 15:46:37
Did you put the orfice blocking plug in passage before installing left control valve?
Salty
11-25-2007 16:24:56
 Re: 350 Power Steering in reply to D Slater, 11-25-2007 15:46:37
Tell me more about that orifice plug! I did not install one and so I need help to figure out where it goes and what it does!
D Slater
11-25-2007 17:29:58
 Re: 350 Power Steering in reply to Salty, 11-25-2007 16:24:56
Think maybe IH already designed the hydraulic system before they thought about adding power steering. Anyway with the pressure regulator and priority valve for power steering installed the fluid flow for one port is redirected through the U shaped pipe and the port thats used when just a pressure regulator and relief valve is used is blocked with the plug. Its just a small slip in plug that goes in lower hole of the 3 on the support tower and the oring seals it. If your lucky it may still be stuck in tractor it was removed from. If you can't find one I have used a 1/4 inch pipe plug that uses a allen wrench to install. Tap hole with 1/4 inch pipe tap and catch all cuttings,screw plug in untill flush or slightly below surface.
Salty
11-26-2007 16:56:02
 Re: 350 Power Steering in reply to D Slater, 11-25-2007 17:29:58
I second the comment of Randy above! I would have spent many moons trying to figure out what was wrong. It is awfully nice of you to be so helpful! I was about to look at an auxiliary hydraulic pump driven off the fan belt to run the power steering!
G Johnson
11-25-2007 20:27:17
D Slater
I have a IH 300 utility that I got last year and it came with power steering, however it is doing the exact same thing as this 350. It only works when I am using the lift. Should I be looking for the same plug? I would appreciate any help, I have had this thing apart many times and I can't find anything damaged or broken. Thank you
Gary
D Slater
11-26-2007 13:59:06
 Re: 350 Power Steering in reply to G Johnson, 11-25-2007 20:27:17
I'm mostly a row crop person and have only worked on powertrain of utility models. Can't say how the fluid flows in that set up. Defective or worn parts in the priority valve will have the same symptom as described also. Sorry I can't be of more help.
Janicholson
11-25-2007 14:51:21
Steven is on target, Priority valve stuck,, not adjusted, plumbed backwards. JimN
Steven f/AZ
11-25-2007 14:33:37
I would have to guess that you don't have the priority valve plumbed right.
Salty
11-25-2007 15:35:16
 Re: 350 Power Steering in reply to Steven f/AZ, 11-25-2007 14:33:37
There are two outlets on the bottom of the priority valve - a small one that goes to the Behlen unit and a large one that connects to the back of the left most hydraulic control valve via a u tube. I have two of those valves here and they both work the same!
