Farmall H hydraulic conversion
Vito
11-25-2007 16:44:57
I have a 1951 Farmall H that has a belly pump.Is it possible to remove the pump ,seal it of with a plate and use this as a resevoir than install a live pump and tank from a Super H to get live hydraulics and increased oil capacity.Will the battery get in the way of the external tank?.Any thoughts would be appreciated.
Thank you
Vito
Nat 2
11-26-2007 07:23:41
 Re: Farmall H hydraulic conversion in reply to DickelDawg, 11-25-2007 16:44:57
You don't want to use the belly cavity as a reservoir. The clutch is in there, and it's a dry clutch. It won't take well to floating in a pool of oil.
All you need to go live is a live pump, any old oil tank, and an open center spool valve. It doesn't have to be a Super H tank.
The problem with a Super H tank is it will interfere with the battery. That's why they moved the battery back under the seat on Super Hs with the live hydraulic setup.
chuck46
11-25-2007 20:33:01
 Re: Farmall H hydraulic conversion in reply to Vito, 11-25-2007 16:44:57
Hi Vito, I think sealing up the belly would be more trouble than it is worth. When I put live hyd. on I chose to use the transmission and rear end as a resivoir. That was over 30 years ago, after several thousand hours I still think it is by far the best. I draw from the drain plug in the rear, the first filter is a 1 inch pipe cross, use plastic plugs in the side holes they have a hollow center in which there is a cow magnet suspended. Then a suction strainer and also a 10 micron filter in the return line which goes to the oil check plug on the left side. There I put a street ell and then a tee, use the side hole with a plug as the oil check. This raises the oil level at least 2 inchs, with Hy-tran I now I have gotten longer bearing life and have no problem with a bearing turning in the casting like I had before. The pump I got from TSC for about 70 bucks still works like new. I did the WD9 the same way and it has worked very well too. Good luck, Chuck
Steven f/AZ
11-25-2007 17:00:52
I put a belt drive pump on my H, about 15 gpm at full throttle... I put a plate where the pump was and use the belly pump casting as a reservoir. It does not have enough capacity to keep the oil cool so I had to add an oil cooler.
Runs my power steering and everything I need it to, the belt limits me to about 1000 psi before it slips.
third party image
third party image
