Add live hydraulics to M?
Carden
11-27-2007 06:24:56
Pardon my ignorance... My M requires the clutch to be out before the hydraulics will work. I have gathered, from this forum, this means I do not have "live" hydraulics. I found this on the parts page - Hydraulic Pump - For models: M, Super M, Super MTA, Super W6, Super W9, 400, 450, All Gas with Live Hydraulics. (Part No: 128190C91)- $650 - Is this what is required to make the hydraulics live on my M? If so, how difficult is it to install? Does this automatically mean it will be 2 way (up & down) pressure or will I still need the correct valve?
MN Rick
11-27-2007 18:28:56
 Re: Add live hydraulics to M? in reply to Carden, 11-27-2007 06:24:56
Got a couple pumps...give me a holler. Thanks
superbn
11-27-2007 11:40:55
Does anybody know what cam and gear are better for the live hyd? I know the supers and 400 series has a different cam but are they left or right handed threads?
glennster
11-27-2007 12:37:20
 Re: Add live hydraulics to M? in reply to superbn, 11-27-2007 11:40:55
if you are doing the live pump on the m use the cam drive gear from the super m. it is a lot heavier gear than the old m had, the old gear wont handle the pump and after a while it will let go. been there done that. you dont need to change the camshaft for the live pump. if you dont change the front engine timing cover, you can plug the top two mounting holes with grade 2 bolts, cut them off flat with the cover, then mount the live pump using the bottom 2 bolts, and redrill and tap the top 2 bolt holes in the cover. dont drill thru the cover tho!!
Carden
11-27-2007 15:16:58
 Re: Add live hydraulics to M? in reply to glennster, 11-27-2007 12:37:20
It"s interesting that the pump listed says for all of the M,W6,400 etc. It must be the heavier duty model you are talking about. Is it unusual for it to be $650 dollars? Thanks for the info and i"ll be sure not to drill thru the hood!
glennster
11-27-2007 16:52:09
 Re: Add live hydraulics to M? in reply to Carden, 11-27-2007 15:16:58
yup thats the price for the pump, its a killer. you may try and find a good used pump, will save you some coinage. rusty farmall and nebraska cowman both post on this site, give em a hollar, they can prolly scare a decent pump up for ya. i hear tell them two rascals know "where the devils got little ones" when it comes to finding old tractor parts!!! they can prolly find a good used cam gear too.
Jim J
11-27-2007 15:15:10
I know M's that are still running after 30 years with the original M cam gear.
wh
11-27-2007 09:42:24
i did the same thing to a "H". changed the front engine cover out to match the pump. used a cover from a 300 -- you may need a cover from a 400. there is a way to do it without changing. link will show my setup. i also built an external tank that holds 7 gallon of fluid.
Carden
11-27-2007 15:18:47
 Re: Add live hydraulics to M? in reply to wh, 11-27-2007 09:42:24
Thanks for the link. Pictures are sometimes worth... you know the rest. The box with the 2 levers on top, that is the hydraulic reservoir?
wh
11-27-2007 16:46:23
 Re: Add live hydraulics to M? in reply to Carden, 11-27-2007 15:18:47
yes -- mounted it to the 3 pt frame. totally bypass the belly pump. i just filled it with oil and left it unhooked. i could give you the dimensions if you need them. tank holds almost 7 gallons. if you look you will see a filter in the return line at the tank. i also have a wire screen filter in the tank at the suction port. bought the screen, tank filler cap and filter from northen tool.
old
11-27-2007 07:02:35
Yep you can put them on and yes or no you can have hyds either way. You do have to pull the distubutor to install it and if you have the wrong cam gear it will not last very long.
