Belt pulley removal
njs
11-27-2007 19:47:16
I want to remove my belt pulley from my H. Its missing the pulley, the seal leaks and it grinds terrible when you run it. How big of a job is it to fabricate a cover for the hole? Is there any factory covers out there?
Pat-CT
11-28-2007 06:41:34
 Re: Belt pulley removal in reply to njs, 11-27-2007 19:47:16
is as pie i jsut did mine with aluminum take the belt pulley off get a can of spray paint lay the belt pulley down on a piece of metal and spark around the whole thing..you got your outline..cut it and drill holes
DCW
11-28-2007 02:08:05
The Super M I have came from the factory without the belt pulley,I have a cover plate.Its an easy enough plate to fabricate.Its about 3/16 thick.
MN Scott
11-27-2007 20:46:59
There's one on Ebay right now but it would be easy to make one out of 3/16 or 1/4 plate steel.
CenTexFarmall
11-27-2007 19:53:37
I've seen M's that did not come with the belt pulley and had a cover. I'm sure some H's were like that too. Unbolt the perimeter bolts from the belt pulley and it'll pull right out. Have some help though asthey are quite heavy! Then you can make a template out of cardboard of the opening to use as a pattern to make a steel cover. I have an M with a factory cover and it's about 1/8" or so thick.
William Stubbs
11-27-2007 20:23:23
 Re: Belt pulley removal in reply to CenTexFarmall, 11-27-2007 19:53:37
I have been restoring a '47 H. I have a plate where the pulley normally is. I would consider swapping my cover plate for your pulley. My cover plate does look sort of home made. Shipping costs might be a problem. I am located in Santa Rosa, CA
Best Regards,
Bill
