A little help from the experts.
Younger
11-28-2007 07:39:08
I have an original condition 1948 F Cub that I am restoring. The tractor is in excellent condition both mechanically and cosmetically, with the exception of a few nicks and faded paint. I am planning on having it painted soon, and want to do everything I can to achieve perfection prior to the paintbooth. Here is a little rundown on what I have done:
degreased tractor changed oil/filter changed trans and steering box lube repaired bent clutch insp plate installed new implement mounting bolts replaced all hoses and tower clamps flushed and refilled cooling system cleaned breather and intake caps cleaned oil cup
Things left to be done:
change final drive oil and gaskets r&r front tires clean, inspect and grease wheel bearings replace 2 dented light rings r & r wiring harness replace grommets (before or after painting??) check front wheel wobble replace seat with original type replace grille and side wings
What other things should I be looking for? I do not want to be messing around fixing things after the paint job. The carb leaks when the gas is left on. Should I rebuild it?? It appears that nothing else is leaking, so should I skip replacing various seals and gaskets??
Any and all tips would be appreciated.
BOBM25
11-29-2007 09:25:01
 Re: A little help from the experts. in reply to Younger, 11-28-2007 07:39:08
I wouldn't replace any seals or gaskets that are not leaking. Often the new replacement gasket is not as good as the old one and will leak as soon as you put it in. I tinkered with my MTA for over 2 years, fixing everything I thought it needed and running it alot trying to find new things. I wanted a perfect restoration job that would astound everyone anywhere it went. I finally gave up thinking something else would go bad and painted it. The paint wasn't even dry before I noticed a new leak on the pto housing. I rebuilt the carb before paint and it worked great, now the needle or float is sticking and it runs over, so I have to take it apart. Any job worth doing is worth doing right, but be prepared to put a wrench on a bolt head with nice, new, shiny paint on it, because it's gonna happen.
El Toro
11-28-2007 13:45:15
I would use either PPG's Omni Single Stage paint
or Martin Senours Crossfire paint. If you want to see a tractor painted with Martin Senour's let me and I will post a picture. Hal
Allan In NE
11-28-2007 08:13:47
Just my 2 cents?
Make sure all leaks are repaired and dry.
Then..... ..... ..... ....don't paint it with one of those flashy, wet-look, dull coat/clear coat, mirrored automotive finishes.
Makes 'em look like, and as phoney as, a cheap $3 hooker. :>)
Like I say, just my opinion,
Allan
Quebec Red
11-28-2007 19:09:03
 Re: A little help from the experts. in reply to Allan In NE, 11-28-2007 08:13:47
Now Allan, if you would be referring to $3.00 in Canadian funds, you might have something interesting..... .QR
Andrew Z
11-28-2007 08:14:10
 Re: A little help from the experts. in reply to Andrew Z, 11-28-2007 08:05:34
Sorry you did change that oil
Andew
Bob Kerr
11-28-2007 08:01:17
The best paint jobs start with being stripped to bare metal first. Remember, any imperfection including chips in paint that are just feather sanded will show up in the final finish. Small rust pits and or dust and dirt will show also. it can be a big job, but if done well will look super instead of mediocre.
