w-9 Info
MWILKE
11-28-2007 15:44:36
I looked at a W-9 today that I would like to add to my collection. I noticed that the flywheel was open on either side of the tractor. Is that a normal condition for the tractor. I have had no exposure to W-9"s in my area. I am interested since it is available and relatively close to home. It would complete my letter saeries in horsepower categories.
Mike
Steven f/AZ
11-29-2007 06:35:43
 Re: w-9 Info in reply to MWILKE, 11-28-2007 15:44:36
It sounds as though you might be missing the felt that goes into those slots... no big deal at all.
mtdan
11-29-2007 06:12:03
If it is missing the clutch cover there would be nothing to hold up the fuel tank and or air cleaner. the W9s have a wide gap between the frame rail and engine.. about 3/4" had a felt in there from the factory.. other then that it is closed.. Dan
glennster
11-29-2007 06:02:17
here is a picture from the parts book on the chassis and rear axle housing. i"d guess you are missing #5 clutch compartment cover
third party image
MWILKE
11-29-2007 08:34:27
 Re: w-9 Info in reply to glennster, 11-29-2007 06:02:17
Glennster, you provided the answer in a picture and it is consistent with the other answers. From the picture, I can see that it is the felt strip that I need on each side of the engine block. As I described, the open areas are on each side of the engine block and item #6 in the parts diagram is the missing part.
Thank all of you for the responses.
Mike
glennster
11-29-2007 08:50:29
 Re: w-9 Info in reply to MWILKE, 11-29-2007 08:34:27
mwilke, heres a pic of my w-9, i really like the ole girl, dualed up she looks like a fat baby in tight diapers. she will pull a 14 ft disk, or 3-18 plow no problem. i have power steering on mine and a pto mount hydraulic pump. real comfortable tractor to drive too!!!
third party image
MWILKE
12-01-2007 07:33:12
 Re: w-9 Info in reply to glennster, 11-29-2007 08:50:29
Glennster, it looks loke you have a nice line going there, I have a W-6, Super H, C and a Cub that all run. I have a SC that I bought with some implements that doesn't run. Do you have any idea what is a fair price for the W-9? It is in MO and does not anything but a PTO-no hyd or pulley & wrong seat. Have't heard it run.
Thanks
Wardner
11-28-2007 17:03:30
The tractor is missing the "clutch compartment cover". It is a casting and is held on with four bolts and a dowel pin.
MWILKE
11-28-2007 20:05:02
 Re: w-9 Info in reply to Wardner, 11-28-2007 17:03:30
Are you talking about the top casting? The exposure I am talking about is on the sides. There a cover on top of the flywheel
Thanks
Wardner
11-28-2007 20:37:39
 Re: w-9 Info in reply to MWILKE, 11-28-2007 20:05:02
You have had two opportunities to describe the opening. What about the shape? What about the size? A picture would be even better.
