Need help on brake bearings on my 43 H
neblinc
11-29-2007 06:43:29
Looks like the bearings on the brake shaft are worn, do I just remove the plate on the side to replace them, or is it more involved than that?
Randy
43 H Pics
third party image
Steven f/AZ
11-29-2007 16:38:18
 Re: Need help on brake bearings on my 43 H in reply to RustyFarmall, 11-29-2007 06:43:29
GeneMO said: (quoted from post at 14:27:52 11/29/07) Steven, you are not the only one to break that housing. I remember when my dad and uncle were installing an M&W hand clutch on our M and I think I recall them breaking that housing then.
Gene
Yep, they even have those nice threaded holes so you can use a couple of bolts to "push" them out, and when the going gets tough, the tough use a breaker bar and hear a loud "crack." third party image
neblinc
11-29-2007 11:19:50
 Re: Need help on brake bearings on my 43 H in reply to neblinc, 11-29-2007 06:43:29
Wonder how many IH-3 & IH-6 manuals were destroyed third party image
Randy
neblinc
11-29-2007 09:58:25
This is what I am looking for.
Amazon
They also sell them here on the YT site under manuals at the top of the page, and at TSC where I will most likely pick one up after work.
Still seems pricey for the money compared to some of the other manuals.
Randy
Mike Farmer
11-29-2007 09:17:07
Hi Gents. Would the gentleman who posted the pages from the manual please post the Book ISBM No so that I can get one the same. MTF
neblinc
11-29-2007 08:25:17
Thanks Glenn!!
So are these from that IT manual called IH-8?
Randy
El Toro
11-29-2007 10:30:54
 Re: Need help on brake bearings on my 43 H in reply to neblinc, 11-29-2007 08:25:17
third party image
I have one of those manuals too. I bought it in 1975. It's a little tattered now. Hal
glennster
11-29-2007 08:55:12
yup thats the ih-8 manual.covers the super and non super a thru d9. wow the price really went up. my manual was from tractor supply quite some time ago, has a price of $4.00 dollars on it. man, i'm getting old!!!!
neblinc
11-29-2007 07:49:25
glennster, what book do you have that shows this info? I need to pick one up. I see the IT manual at TSC for the H's, but seems like very few pages for the $25+ price, plus it is wrapped so I can't see what info is really in there.
This H was just supposed to be "fix a few leaks, ready to paint" project. But has sure turned into more than that.
Randy
glennster
11-29-2007 08:07:44
 Re: Need help on brake bearings on my 43 H in reply to neblinc, 11-29-2007 07:49:25
randy, its the i and t manual, i scanned the two pages for ya, here ya go. if ya need any others lemme know!!!! glenn
third party image
third party image
Eastsider
11-29-2007 07:50:33
It is an involved process...however, with the transmission top off already you are about half done...you will need to remove both axels and housings so the bull gears can come out...it is a great time to check the bearings all over then...new gaskets for the axel housings are probably needed anyhow, so while you are there.....After removing the bull gears, then you can unbolt the pinions and differential and take it all out to inspect and repair.
mark
Steven f/AZ
11-29-2007 07:22:39
It's more involved than that!
You have to remove the big bull gears to get the bearing cages to come out the side. I broke the first one on my tractor by just trying to pull it out the side without removing the bull gear!
If I remember correctly, the axles have to be slid out to get the bull gears off.
GeneMO
11-29-2007 13:27:52
 Re: Need help on brake bearings on my 43 H in reply to Steven f/AZ, 11-29-2007 07:22:39
Gene
glennster
11-29-2007 07:26:10
randy, i looked in the i and t book, kinda looks like you will need to pull the bull pinions, according to the book, the bearings come out with the bull pinions as an assembly. if you need the instructions, lemme know, i can scan the pages and post em for you.
