Farmall H 1943 gas tanks
Beth Creager
11-29-2007 10:08:22
What is the 2nd smaller gas tank for on this tractor?
Mike CA
11-29-2007 15:35:42
 Re: Farmall H 1943 gas tanks in reply to Beth Creager, 11-29-2007 10:08:22
Beth Creager said: What is the 2nd smaller gas tank for on this tractor?
It's nothing. You don't want it. I'll give you $10 just so you don't have to deal with it any more.
*edit, I see some people already told you the real value.
Rats. third party image
hehehe third party image
sammy the RED
11-29-2007 12:41:20
 Re: Farmall H 1943 gas tanks in reply to Yugrotcart, 11-29-2007 10:08:22
Beth Creager said: (quoted from post at 00:08:22 11/30/07) What is the 2nd smaller gas tank for on this tractor?
It Is For Gasoline.
Andy Motteberg
11-29-2007 12:29:38
That is the starting tank. Used on all fuel/kerosene models. You put gas in the small tank & distillate or kerosene in the large tank. The tractor starts on gasoline, and then you switch it over to distillate or kerosene. That was cheaper a long time ago, but now most all of them run on gasoline.
gene bender
11-29-2007 11:15:30
Thereis one on e-bay probably will bring 100
old
11-29-2007 10:19:31
You lucky dog. Most of those small gas tanks have long since been trashed so if you still have one you have a good bit of $$ under that hood. Thats is as the other guy said your gas starting tank and the bigger tank is for kero
glennster
11-29-2007 10:16:31
the smalltank, about 7/8 of a gallon was the starting tanks for gasoline on a distillate or kerosene tractor. , you would start the tractor on gas, let it warm up, then close the valve to the gasoline tank and open the valve on the main tank to switch to the other fuel
Beth Creager
11-29-2007 10:18:19
 Re: Farmall H 1943 gas tanks in reply to glennster, 11-29-2007 10:16:31
Thank you very much. That is what we thought it was, but just wanted to be sure !!
glennster
11-29-2007 10:23:57
 Re: Farmall H 1943 gas tanks in reply to Beth Creager, 11-29-2007 10:18:19
beth, if this is your tractor, it may have been converted years ago for gasoline. they would switch cylinder heads for higher compression, altho, it will still run on the old head. it may or may not still have the shudders in front of the radiator too.
