Farmall 460 T)A HELP
ironpony
11-30-2007 05:18:48
I have a 1959 460 gas With a T/A that has never works sinec the day i bought it used when you pull the lever it chatters and the tractor stops moveing. I never thought this would be importantbut now it is i have a pto combine that i need 540 rateed RPM and slow grounf speed which i think the T/A would give me. what go wrong with them does the rust up from no use or get out of adjustment real bad can they be repair or just buy one on ebay. if I that the top cover off the trans. can i get a good look at it to see what wrong.
thanks guy for you input!!!
ironpony
Steven f/AZ
11-30-2007 16:20:45
 Re: Farmall 460 T)A HELP in reply to Stan - Florida, 11-30-2007 05:18:48
jk said: (quoted from post at 17:00:12 11/30/07) don't forget that turning off the enggine with the TA pulled back )in TA mode( can hurt it too, as some IH engines rock backwards when there winding down. thats what my gandpa told me, and his 350U does it to
Yes, I have heard that as well, always turn off engine with lever ahead... on the Oliver over/under shift you should always turn off in direct.
Steven f/AZ
11-30-2007 06:15:05
 Re: Farmall 460 T)A HELP in reply to ironpony, 11-30-2007 05:18:48
Your TA sounds to be completely shot. That will require splitting the tractor, twice. You need to split at the bell housing/clutch area and again split the middle section away from the transmission/rearend.
A rebuilt TA unit is anywhere from $400 to $600 plus core charge. While you have it apart you will also want to put in a new TA clutch, and probably main clutch as well so you don't have to go back in there for a long, long time.
Yes, the TA can be used constantly - the main things that make a TA go out are: rolling backwards while in gear, freewheeling while the TA is in low range, and shifting the TA too slowly.
jk
11-30-2007 16:00:12
 Re: Farmall 460 T)A HELP in reply to Steven f/AZ, 11-30-2007 06:15:05
Redman47
11-30-2007 06:17:49
Hi
I just fixed one on a 460 that had a bad clutch now am working on a 340 that has a bad ramp that acts like yours. It doesn't hurt the ta to use it all time as long as you are pulling a load as it does't hold back down hill it freewheels downhill which is not good for it. If you want you can call me and I will explain more the # 859 289 8818 6 to 10PM eastern time.
ironpony
11-30-2007 05:20:15
sorry about my typing and spelling hope you can make out what i was asking. also can you run the T/a all the time?
Kevin Meier
11-30-2007 14:21:18
 Re: Farmall 460 T)A HELP in reply to ironpony, 11-30-2007 05:20:15
It sounds like your ramp is either out or you may have broken a sungear. Depending on what your tractor does when you shift it. I have the t/a or parts to rebuild in stock. If interested feel free to send me an email. I also show a couple different t/a"s fitting the 460 be sure to measure the bearing area of the back gear and also the tooth length to get the correct part you need.
