New Farmall H owner with questions
RockyMO
11-30-2007 08:52:36
Hi guys, I have been around tractors for a while now but not the Farmalls. Anyway, I bought a model H this morning serial number FBH 359321 X1. The seller thought the clutch was out because he could not get it to move. After playing with it for a while I got it to take off and move just fine. I shifted through all the gears, 1-4 were ok. When I put it in 5th the speed was to fast for the area I had to drive it in so I stopped and put it back in 1st. The tractor would not move again and acted like it was stuck in 2 gears. After playing with it some more you could feel it pop out of 5th into neutral then it would move in the lower gears again. I am looking for any info or best guesses you might have. I will be ordering a manual but have not got one as of yet (only had the tractor 2 hours). Thanks in advance,
RockyMO
1942 Ford 2N
1953 Ferguson TO 30
Massey Ferguson 2135
Oliver HG
Real tractors have tracks
and a farmall H
Paul Shuler
12-01-2007 13:27:17
 Re: New Farmall H owner with questions in reply to RockyMO, 11-30-2007 08:52:36
Where are you at Rocky? I'm just a few miles west of Springfield.
Andy Martin
11-30-2007 13:18:52
You can use this as an anti-theft device. So long as you carefully shift straight out of 5th into neutral (or out of any other gear for that matter) you can use it like it is.
Nebraska Cowman
11-30-2007 09:26:18
 Re: New Farmall H owner with questions in reply to Janicholson, 11-30-2007 08:52:36
Yeah, The shifetr needs to look like this. A little welding and grinding should fix it. You might have to put in an oversize pin as well if that part is worn.
third party image
RockyMO
11-30-2007 10:35:18
 Re: New Farmall H owner with questions in reply to Nebraska Cowman, 11-30-2007 09:26:18
Thanks for the reply, a picture sure is helpful. It sounds unanimous as to where I need to start.
RockyMO
1942 Ford 2N
1953 Ferguson TO 30
Oliver HG
and a farmall H
old
11-30-2007 14:41:47
 Re: New Farmall H owner with questions in reply to RockyMO, 11-30-2007 10:35:18
Rocky if you find you need parts for that H let me know I have an almost complete H for parts
Ksfarmmer
11-30-2007 09:13:50
We never had an "H", but I assume it is no different than other Farmalls. Pull the gear shift lever off and you'll see three slides that push the transmission into the five forward gears and reverse. Normally what happens is two of the slides have moved and, as you thought, locked the transmission in two gears. Using a large screw driver you can usually get the slides back to the neutral position. If it continues to happen, you probably need to build up the end of the gear shift lever so it doesn"t allow two gears to engage at once. It is a common problem, the archives should have more info.
RockyMO
11-30-2007 10:36:21
 Re: New Farmall H owner with questions in reply to Ksfarmmer, 11-30-2007 09:13:50
Thanks for the info. It seems unanimous on where to start.
RockyMO
1942 Ford 2N
1953 Ferguson TO 30
Oliver HG
and a farmall H
Wayne from MN
11-30-2007 09:09:30
Likely the end of the shift lever is worn and needs either: 1. remove, buy new, & replace or 2. remove, weld up, grind to shape, & replace.
This is a common problem with 50+ years of shifting wear.
RockyMO
11-30-2007 10:37:20
 Re: New Farmall H owner with questions in reply to Wayne from MN, 11-30-2007 09:09:30
RockyMO
1942 Ford 2N
1953 Ferguson TO 30
Oliver HG
and a farmall H
Janicholson
11-30-2007 08:55:15
Put this question in the box called search for. It is the most often repeated Farmall question. --H stuck in two gears--
JimN
williamf
12-01-2007 03:56:35
 Re: New Farmall H owner with questions in reply to Janicholson, 11-30-2007 08:55:15
May be, Jim. But I would have thought it was, "H jumps out of 5th" ;-)
Good luck, Wm
RockyMO
11-30-2007 10:37:52
RockyMO
1942 Ford 2N
1953 Ferguson TO 30
Oliver HG
and a farmall H
