Farmall A rear tire size
oldgit
12-01-2007 06:34:25
I have an old A that needs a new rear tire. The old tire size is 10-24. I cant find one any where so I would like to know is an 11.2 about the same size or what would be my best option. The tire on the other side is in great shape but I hit a piece of steel with the right side that just slit it from sidewall to sidewall.
gene bender
12-01-2007 08:51:02
 Re: Farmall A rear tire size in reply to oldgit, 12-01-2007 06:34:25
Measure your rims they are probably 8in and the 9.5 is a good fit. A lot depends on the tractor use. Do you need lots of traction. Too big of a tire and you can lose H.P. real quick as the A is not powerful to start with.
oldgit
12-01-2007 06:55:06
Thank you all that replied! I thought it was the same size but wanted to make sure.
Thanks again,
Oldgit
J.J. from Afton
12-01-2007 06:41:56
11.2-24 is the modern number that is equal to 10-24 from when they changed how they measured tire sizes somtime back in the 1960s.
J.J. from Afton
12-01-2007 06:41:50
Dave_Id
12-01-2007 06:38:39
Click onto to Misc, then Faq's, and a chart will come up showing old and new tire size equivalents.
RustyFarmall
12-01-2007 06:38:13
I think the 11.2 replaced the 10. It is the same size tire, it is just measured in a different place.
oldgit
12-01-2007 06:55:57
 Re: Farmall A rear tire size in reply to RustyFarmall, 12-01-2007 06:38:13
Thanks again,
Oldgit
