decision
kirk in ks,
12-01-2007 06:41:00
I was just on the IH file but i was thnking about 1466 too, i like controls alot better on the IH's the deeres and i think you can get one cheaper with less hype than a JD, is there anytrouble spots with the levers on right side of dash other than getting loose over the yrs from use, ilkethe throttle lever better than the deeres too, up out of the way,
gms
12-01-2007 07:14:13
 Re: decision in reply to kirk in ks,, 12-01-2007 06:41:00
Make sure the toqure is good that can get spendy to rebuild. They all seem to leak a little oil down on the left side below the seat we have a 806,1206 and a 1466 and other then the shifting being alittle loose they all good tractors. we dont use our much anymore just pull wagons and run the augers.I think they did there share of hard work .
