IH 2400 loader/backhoe
danielm
12-01-2007 07:01:18
I"m looking to purchase this tractor to use around the farm. Seller says the backhoe boom failed to swing last time he tried it. Looking at the parts drawing I see it is a rack and pinion type mech. The rack has a piston on each end for the left and right hyd cylinders. I was told these parts are NLA. The seller seems to think its a problem with the operating lever spool. Is there an easy way to check what might be the problem without tearing into it? I belive I will pass if its a rack and pinion issue. Also, this tractor has the forward/reverse lever on the dash. It looks as though it operates a valve on top of the trans. Are these shuttle shifts problematic? I am having to get the starter rebuilt to check it out. So, I"m in it for about $50 so far. I"m finding little info about this machine. Anyone familiar?
danielm
12-01-2007 20:40:06
 Re: IH 2400 loader/backhoe in reply to danielm, 12-01-2007 07:01:18
13Klbs! My trailer won't like that.
Do the two pumps use a common resevoir?
JLE
12-01-2007 16:36:26
Two hyd. pumps run this backhoe one for swing and steering, the other runs the rest of the hoe and loader. Once you get it runing email me and maybe I can help you. Jim
danielm
12-01-2007 08:26:21
Also, I can't locate a weight for this machine.
I'm guessing around 6K lbs.
maplehillfrm,pat
12-01-2007 16:45:28
 Re: IH 2400 loader/backhoe in reply to danielm, 12-01-2007 08:26:21
I am not sure how much difference is in teh 2500A and the 2400, but weight wise I believe you are way off, I know my 2500A backhoe weighs close to 13,000 maybe more,,, hope that helps
