H steering universal joint
akb
12-01-2007 15:33:18
The u joint is bad. It is the key way type. All the new ones I have seen are the pin style to secure it to the shafts.Is the fix cutting the u joint housing off the steering shaft and drilling cross holes in the 2 shafts or can you get the keyed style somewhere ?
Nebraska Kirk
12-01-2007 17:05:07
 Re: H steering universal joint in reply to akb, 12-01-2007 15:33:18
New U-joints are available from the Case/IH dealer. You should not have to replace the yokes, just the cross.
RustyFarmall
12-01-2007 19:19:48
 Re: H steering universal joint in reply to Nebraska Kirk, 12-01-2007 17:05:07
There is an early style U-joint, and a late style. The replacement cross is availabe for the late style. It is not available for the early style.
Nebraska Cowman
12-01-2007 16:09:23
The original was welded to the shaft. So yes, unless you want to buy a used shaft you will need to retrofit.
