560hydraulic pressure
joe moyer
12-01-2007 19:29:06
need to adjust pressure on a 560
how do i do it?
thanks
GD720D
12-04-2007 07:23:19
 Re: 560hydraulic pressure in reply to joe moyer, 12-01-2007 19:29:06
The prerssure regulator is behind the cover on the aux. valves. Take cover off regulator is on the lower left side. It will have a cap with four bolts in it. Remove the bolts. It takes two different lenghts of bolts to get cover on and off bedcause there is a big spring under the cover. Might need to get a new gasket for cover. Add narrow rim washer under the big spring. I wouldn't go over 1500-1600 hundred psi. That system wasn't made for to much pressure
