450 power steering pump
Bill thompson
12-02-2007 07:26:39
I had a hydraulic line leaking at the power steering pump. Changed that and the two O rings in power hydr pump. How do you get fluid back in the line? It has gotten better by turning the wheel but not like it was and the pump has a high pitch sound. If you turn the steering wheel a little with your finger the sound stops. Thanks Bill
georgeky
12-02-2007 08:31:15
 Re: 450 power steering pump in reply to Bill thompson, 12-02-2007 07:26:39
Power steering pump or hydraulic pump.If the 450 has factory power steering it drives off the hydraulic pump mounted at the front right side of engine. If it has aftermarket power steering it could have a pump mounted on the left side of engine, or drive off the hydraulic pump. Try removing the filler cap, and turning the wheel several times to release any air that may be trapped in the system. Most the time whining is from air in the system.
Bill thompson
12-02-2007 09:12:09
 Re: 450 power steering pump in reply to georgeky, 12-02-2007 08:31:15
Thanks!!!!! ! It worked great. I think I have all the leaks fixed, Now I can change the trans- hydro fluid.
