Model A Oil check
Dick357
12-02-2007 09:37:15
Just purchased a 1940 "A" I think checking the oil must have something to do with the petcocks on the side of the oil pan, am I right? One is slightly higher than the other.
georgeky
12-02-2007 13:01:20
 Re: Model A Oil check in reply to Dick357, 12-02-2007 09:37:15
Yes, when filling, fill until oil drips from the top petcock. The lower will indicate when you need to add oil. When checking your oil, as long as some runs out the lower petcock you are good to go.
gene bender
12-02-2007 09:42:49
Correct
