Dowel Pins/ I,O,W4s
L.C.Gray
12-02-2007 10:47:31
I've fooled around and lost a coffee can full of bolts for the I-4 I'm working on. Most of the bolts in it are replacable with no problem, but there's two I don't know about.
Going down vertically through the rear plate of the engine into the clutch housing are two dowel pins that locate the engine straight in the chassis. The dowel pins are threaded on the ends to allow them to be pulled out for engine removal.
I have searched the CNH parts site and can't get it to pull up anything for an I, O or a W. I'm searching now to find the similar pins I think are used horizontally on the H. Does anyone know if the pins are the same part number? Are they still available from CNH Parts today?
GeneMO
12-02-2007 12:19:57
 Re: Dowel Pins/ I,O,W4s in reply to L.C.Gray, 12-02-2007 10:47:31
I would think they could be obtained from Case/IH, as they should be very common. I have just split my Super H in both places. Each side of the split had two dowels. The threads are a little messed up on mine and i was considering replacing them.
Gene
