New Distillate/Kero manifold?
Mike CA
12-02-2007 14:12:04
Does anyone make new Distillate / Kerosene manifolds? I've never seen a new one, and the old ones I see have the selector vavle messed up usually.
Mike CA
12-03-2007 19:42:38
 Re: New Distillate/Kero manifold? in reply to Mike CA, 12-02-2007 14:12:04
Depending on condition I'd say $50-$100.
Mike Farmer
12-03-2007 13:12:23
At a guess that valve is stuck in the distillate position. So unless you are going to use it all year round as a working tractor I wouldn't worry too much about it. It is personal but I believe that a good radiator Blind (shutter) is more important. Incidentally if you try to shift that valve and get it wrong best you start learning to weld old cast iron and that can be real fun. MTF
georgeky
12-02-2007 15:27:19
Used one on ebay now.
Gauger
12-02-2007 14:29:55
I'd say no, but I wish I were wrong. I could use a new one for my Stage II Super H. If anyone has a junk H distillate manifold with most of the flapper left intact I'd like to buy it. It need not be adjustable, I'd like to cut the flapper out and transplant it.
Lee Cramsey
12-03-2007 18:46:24
 Re: New Distillate/Kero manifold? in reply to Gauger, 12-02-2007 14:29:55
I spoke to a man yesterday who has an H distillate manifold he wants to get rid of. What is the approximate value of one. I imagine the valve is stuck, but it looks ok. Has a carb on it. I don't know if it is gas or kero. Lee
