Re: 450 gas think float is sticking?
Bill thompson
12-02-2007 14:20:22
This worked for me on my 450. I took the carb drain plug off. Then took the gas line off and sprayed a lot of carb cleaner in thru the gas line hole. Then put the plug in and sprayed more in. Let it sit for an hour or two. Took the drain plug out and sprayed air from the air compresser in the gas line hole. Put it back together and it worked. I guess I was lucky. I now close the gas line and run it till it stops like my Dad always told me to do.
