Power Steering 560 Gas
tlee
12-03-2007 07:04:36
anybody know if the oil has to warm up good before the power steering works ...used it the other day and power steering wouldn't work until tractor ran for about 15 minutes...it was cold out about 10 degrees and did not have it plugged in...used it the next day with tractor plugged in and it worked right away....have 15-40 oil in engine..... ..Question is - is it oil that needs to get warmed up or the beginning of a power steering problem.....
ChrisAS
12-03-2007 20:03:41
 Re: Power Steering 560 Gas in reply to tlee, 12-03-2007 07:04:36
560 has 2 pumps one for steering and one for hydraulics they are both in the left side of the TA housing use the same filter which is on the right of TA housing and use the rear end for reservoir. Engine heater should not make difference.
tlee
12-03-2007 07:43:14
Is it run off the hydaulics or does it have a seperate reservor for power steering fluid..Its mounted on left side of tractor but cannot see any place to put in fluid...
