super H oil gauge ?
gms
12-03-2007 16:25:18
We are redoing dads old super H to be like the day he bought it new. So we down to changing to oil gauge so the new one we got does not match the fitting that goes to the gauge cant find one at the case dealer or the hardware store any thoughts?
Gauger
12-03-2007 18:05:34
 Re: super H oil gauge ? in reply to gms, 12-03-2007 16:25:18
Go online to McMaster-Carr. Order a brass fitting / 1/8" female pipe to 1/4" O.D. tube compression. They have a number of different types for alot less than the tractor sites.
El Toro
12-03-2007 16:58:21
If your new gauge has 1/8 male pipe threads you need a brass 1/8 coupling and a 1/4" compression
fitting to 1/8 male pipe threads. You install the brass coupling on the gauge and then install the 1/8 male pipe on the brass fitting into the coupling. Use a little teflon tape on the male threads. Hal
MIKE FRENCH
12-03-2007 16:31:37
Some guages had adapters on them, Should be able to order it from your caseih dealer, if not OEM Tractor pars has them. If need more help email.
