Farmall H Horsepower
dante iocona
12-03-2007 19:41:29
Im looking to set up my distillste / gas 1944 farmall H for Tractor pulling and I need more horsepower.
im looking to buy any motor parts that will help me get there. any information would be appreciated also.
Neb Super H
12-04-2007 10:00:31
 Re: Farmall H Horsepower in reply to dante iocona, 12-03-2007 19:41:29
It really depends what classes you want to pull in. My tractor is stock and I pull Div 1 or Div II in Nebraska.
Div 1- pull what you got and see how you like it
Div II- 20% over on motor- take your H block and bore it to fit 300 sleeves and stepped head or dome top pistons. Port and Polish the head, valve job and deck the head. Turn up the governor to 110% and lift your drawbarup
dante iocona
12-04-2007 14:13:31
 Re: Farmall H Horsepower in reply to Neb Super H, 12-04-2007 10:00:31
What information can you give about rebuilding my govenor, Mine is shot and i have to rebuild,
should i change the spring etc.....
r4etired
12-04-2007 07:06:15
Are you looking for a pullin or field tractor.Cheap pullin, throw away the sleeves and use D-19 AC pistons, you need to bush the pins.can also add 1/8in to piston top. Field work use 3-7/16in pistons and make it a 152cu.in.
dante iocona
12-04-2007 14:17:18
 Re: Farmall H Horsepower in reply to r4etired, 12-04-2007 07:06:15
what doy you meany by bush the pins
Andrew Z
12-04-2007 06:41:37
Also.. I would look at getting a straight gas head off an H, or better yet one off a Super H, 300, 350, i dont have the numbers of hand, but the distilate one you have will limit you somewhat on what you can do for compression, shuld be able to find at least a H head for a reasonable price.
Andrew
Pat-CT
12-04-2007 05:42:43
cold air manifold which has to be made bigger pistons and sleves head shaved and the cam redone also could mayby increase the valve clearance
gene bender
12-04-2007 04:18:32
You need a new set with overbore sleeves and pistons would be the first parts.
