Farmall Super H Live Hydraulics
Matt Weltz
12-04-2007 06:39:11
Hey guys! Have been away from home at college and work so have not had a chance to get the two way valve correctly mounted on my Super H. Have however discovered it is an M&W live pump and 2-way valve. Anyway, wondering if with a live pump if I should still use SAE 30 weight engine oil as my manual recomends for the factory belley pump or if I can use regular hydraulic fluid now with the live pump? Thanks!
tmonton
12-04-2007 11:01:58
 Re: Farmall Super H Live Hydraulics in reply to Matt Weltz, 12-04-2007 06:39:11
Most any non-detergent oil will work. My folks used to use SAE-30 in just about everything.
Detergent oils foam.
Steven f/AZ
12-04-2007 11:00:02
I would use Hy-Tran or hydraulic fluid of some type.
georgeky
12-04-2007 08:05:24
Matt SAE 30 will work in it, but hy tran, SAE 10 or AW-32 hydraulic oil will be a better choice for the winter. The AW-32 is cheaper than Hy Tran and is all you need in systems with their own resivoir. The Hy-Tran is only needed in newer tractors with wet disc brakes, that draw oil from rear end housing.
glennster
12-04-2007 06:49:59
i run hy-tran in all mine, for winter use the belly pump recommendation is 10 wt motor oil. sooo, hy-tran, or its equivalent (like farm and fleet brand hi-tran ) is fine.
