Wrong Hyd Filter
Mixman
12-04-2007 10:14:40
Hoping someone has run into this problem and can help. I was asked to change the hyd. oil and filter on a 2444 with a 2050 loader on it. It has a auxiliary filter hung on the right frame support. I went to the local dealer and ordered a filter 547412R91. That is what it called for. It is the wrong filter and it had the wrong filter in it. There is another filter listed that is way to long. The filter it calls for is a little to long and too big in diameter. We have tried 3 dealers. I'm sure this is the filter canister this came with new.
Owen Aaland
12-05-2007 03:55:23
 Re: Wrong Hyd Filter in reply to Mixman, 12-04-2007 10:14:40
My 2444 with 2050 loader uses filter number 471942R92. I think the other optional filter is shorter and larger diameter.
I also found number 51662 written in my book. That may be a Wix or NAPA number?
migraine
12-04-2007 10:26:55
In cases where things have been changed I just take the one that was in it a find a replacement for that one. If its been a working machine that way it should be ok to continue with the same. Migraine
Mixman
12-04-2007 13:56:10
 Re: Wrong Hyd Filter in reply to migraine, 12-04-2007 10:26:55
The reason for changing the fluid and filter is because is was NOT a working machine!!!!
