Farmall C Crankshaft
Kevin Meier
12-04-2007 14:25:32
I need someone with a crankshaft out of a farmall C to measure the pilot bushing hole without the bushing installed. I am working on having new ones made and I would like to make sure they are going to be correct. Thanks Kevin
gene bender
12-05-2007 03:08:04
 Re: Farmall C Crankshaft in reply to Kevin Meier, 12-04-2007 14:25:32
Why didnt you just get a new one from Dealer? Remember it need to be press fit.
Kevin Meier
12-05-2007 03:36:03
 Re: Farmall C Crankshaft in reply to gene bender, 12-05-2007 03:08:04
I need them to put in my pressure plate kits and I plan on making at least 500 of them. I just need to make me a jig to check them after they are made so I know they will fit. Thanks for the help. Kevin
georgeky
12-04-2007 14:40:06
Kevin, the best I can do you is 1 and 1/8th inside crank, and 7/8ths inside bushing. I don't have my dial here now. I used a tape, so that is good as it gets.
