Farmall-C-123 Engine
1950GM
12-04-2007 17:35:56
First of all got tractor out of the bull briars. Motor turns free, but no distributor. Previous owner said it was parked running, then 5 years later he trys to get running, now he said won't run and dist. doesn't turn. We worked out a deal, now I find gov.,cam,and crank gear are chewed up.All gears came off with sense but I can't get crank gear to budge!!!!! I need some ideas on the next step if anyone can shed some light !!!!! !!!!! !
gene bender
12-05-2007 02:49:29
 Re: Farmall-C-123 Engine in reply to 1950GM, 12-04-2007 17:35:56
You need to heat the crank gear with torch or else press it off as it does need to be super tight.
georgeky
12-04-2007 20:19:11
I have a good crank, and all those gears. Send me an email if interested.
