Please help
Hugh MacDonald
12-04-2007 18:14:51
Can anyone tell me the model number of the this trator by the serial number? 751051 R IH
MJ in the UK
12-05-2007 04:49:18
 Re: Please help in reply to Hugh MacDonald, 12-04-2007 18:14:51
Hi Hugh that part number is a UK tractor part number. The nearest i can get to it is a B275 tractor built at Bradford Yorkshire here in the UK MJ
Hugh MacDonald
12-08-2007 19:23:47
 Re: Please help in reply to MJ in the UK, 12-05-2007 04:49:18
You were rigth. thanks for the help everyone!
Cedric
12-05-2007 00:25:28
International Equipment built in England had 6 digit part numbers beginning with the number 7.
Could the tractor be a B250 or B275, or one of the later models ? Just a thought. Sid.
hugh macdonald
12-05-2007 03:59:31
 Re: Please help in reply to Cedric, 12-05-2007 00:25:28
Thanks for your help. i will try to uplaod a picture to the site today. I had trouble with it last night.
r4etired
12-04-2007 18:27:35
Sounds to me like a part number,I'm thinking the H reached the highest serial no.around 396000.Where on the tractor did you get this number.If you could describe the tractor.size,number of cylinders.sheet metal if any,shape of gas tank.number of gas caps, starter or anything else would help
Hugh MacDonald
12-04-2007 18:38:06
 Re: Please help in reply to r4etired, 12-04-2007 18:27:35
I have a picture. How do i get it to you?
CNKS
12-04-2007 18:20:32
That's a part number, not a serial number. You need to describe the tractor or look at the tractor photos in "Galleries" to your left. The number you gave is 751051 R1, no H. You may have a tractor built in the late 50's or later as most of the older ones do not have part numbers beginning with 7.
CNKS
12-04-2007 18:36:34
 Re: Please help in reply to CNKS, 12-04-2007 18:20:32
Should have said 6 digit numbers beginning with 7.
Hugh MacDonald
12-04-2007 18:36:06
Thank you. i have not been able to find a picture of this tractor anywhere. the closest i have come is something like a 300. It only has one hole in the hood and it is for the air cleaner. How do i send you a picture?
r4etired
12-04-2007 18:43:10
 Re: Please help in reply to Hugh MacDonald, 12-04-2007 18:36:06
Is the tractor a utility,wide front,low to the ground,Any evidence of a International decal on the hood. Does the exhaust go down under the tractor. Sorry I can,t help with posting pictures but someone on this site will help you.
Hugh MacDonald
12-04-2007 18:47:50
 Re: Please help in reply to r4etired, 12-04-2007 18:43:10
Yes to all. There is only one hole in the hood for the air cleaner. It has orchard fenders on it. It's Red.
