Super H, will have to wait
GeneMO
12-04-2007 19:30:48
Shoulder surgery tomorrow morning. The H is split, flywheel and clutch off, Center section is hanging from the hoist, head is off, Parts everywhere! Guess I will go down to the shop, sit in the chair and look at it for 4 or 5 weeks.
Actually I think this is a good time to do an inventory of what I need and start shopping for parts.
May not post as much with one arm in a sling.
Take care all, Gene
ScottyHOMEy
12-05-2007 12:31:38
 Re: Super H, will have to wait in reply to GeneMO, 12-04-2007 19:30:48
I'm with Hugh, and I like your idea, too. Take advantage of the down-time to look over what you've got done already, plan the rest of the job and, as you're able, poke around to try and get in front of any problems that may be lurking.
Best wishes for a successful surgery and a smooth recuperation!
NEsota
12-05-2007 07:33:43
Recently I had major surgery and because of complications, I was introduced to the "wound VAC". It allows healing to happen as much as 500% faster than it might otherwise. Google: "wound vac" or check link for more details.
LA in Wi.
12-05-2007 07:16:29
 Rotator Cuff in reply to GeneMO, 12-04-2007 19:30:48
Gene, Before I had rotator cuff surgery some friends (and a b-i-l) scared the bejeebers out of me by describing all the pain and long recovery I was going to have. I followed the physical therapy exercises very religiously and my recovery was a nearly pain-free breeze. That shoulder is now more flexible that the other one. Makes me wonder if I should have the "normal shoulder" worked on! Eight days after the surgery I rode my mower very slowly and cut some grass....never did tell the Dr. about that. Sure made the wife mad, though.
LA
Stan2270
12-05-2007 07:02:01
Best wishes for a speedy recovery! Stan in Tenn
Steven f/AZ
12-05-2007 06:33:06
Good luck with the surgery. Had my knees worked on a few years back and was limited for several weeks in what I could do - times like those make you appreciate just how good you have it when you are able to walk around and do most everything for yourself.
Take it easy and let it heal properly - no sense ending up back there for the same thing a few years down the road! third party image
Janicholson
12-05-2007 06:26:22
Tie a good generous rag to the vice handle so you can wipe your operational hand off after getting it greasy. Best of fortune, JimN
James Williams
12-05-2007 04:56:14
Gene,Ill be praying for you,I had rotor cup surgy a couple years ago,Had very little pain,a lot of therpy,and sleeping in a recliner for 6 weeks,My wife says she will pray for your wife becaues she knows how us men are
jimmy
Hugh MacKay
12-05-2007 04:31:27
Gene: All the best with the surgery.
This may seem like a bit of a glitch, however just think of the time you'll have carefully looking the tractor over, double checking your double checks. Often time these set backs just give you time to insure nothing is overlooked.
I learned a long time ago, if one going to play with old iron, never pays to be in a rush. Sometimes it just takes that medical condition to instill that in us. Again, good luck, and I'm sure you will be gracing us with your pressence very soon.
Cityboy-McCoy
12-05-2007 04:06:19
Best of luck with your surgery, Gene. Let us hear from you as soon as possible. mike durhan
GeneMO
12-05-2007 03:43:35
Thanks all, Old, it is my left arm, and I am right handed, so that will help. Well I leave here in about an hour, so better git.
Gene
RAW in IA
12-05-2007 02:03:47
Good luck on the surgery. I had rotator cuff surgery a year ago Sept. Right shoulder and I am right handed, but can do most things with lef. I got along real good, and was back at work training a new person and doing paper work in 10 days.
georgeky
12-04-2007 21:14:32
Gene, hope you have a speedy recovery. Nothing wrong with me, and I like sitting in the shop and lookig at parts hanging everywhere. Got me a big lazy boy in ther right beside the stove.
Good luck.
old
12-04-2007 20:36:11
Gene, is it the left wing or the right wing you get to have cut on?? And then are you left or right handed?? BTDT but I also had my knee cut on at the same time. Not fun and depending on what there going to do it may not help it sure didn't with me. Any how being down will let you think about what needs to be done so when you can you might have all your ducks in a row instead of out of line LOL. If you wheren't 100 north of me I'd come up and have that H up and running in a couple days LOL
Mike CA
12-04-2007 19:32:50
Best of luck to you Gene. Keep in touch!
GeneMO
12-04-2007 19:32:20
 Sorry for the double post in reply to GeneMO, 12-04-2007 19:30:48
Not sure what I did wrong,
Gene
Karl Hamson
12-04-2007 22:28:16
 Re: Sorry for the double post in reply to GeneMO, 12-04-2007 19:32:20
Good luck and a speedy recovery Gene. I had my prostate out this spring and 6 weeks with a 10 lb lift limit sort of gives you time to reflect on things and get a few priorities sorted out.
