weights on 1466
Yellott Canby
12-05-2007 04:58:52
Hello,
I was wanting to add more wheel weights to my 1466. I have 16 halves total. Can I put two sets on the inside of the wheel and two on the outside and secure them with just the four bolts(grade 8) per side, or would that be too much weight on the bolts.
Thanks YC
Randy in NE
12-06-2007 05:21:58
 Re: weights on 1466 in reply to Yellott Canby, 12-05-2007 04:58:52
My brothers put about 1,000 lbs on the inside an d 1,000 lbs on the outside of each rear tire on a 1066. Using 4 3/4" all thread bolts that run throug both weigths. The main thing is to keep them tight.
K.B.-826
12-05-2007 16:58:49
That's nothing. I've installed 1400 pound wheel weights on 8000 series Deeres, all they use is three 20mm bolts.
Glenn F.
12-05-2007 05:40:08
Four large, tight, grade eight bolts will hold a tremendous amount. I'd say you can put on as many weights as you want.
Glenn F.
Allan In NE
12-05-2007 05:16:35
I've got a neighbor that runs 4 to 6 sets of the things all on the outside.
Allan
