Bob Kerr
neblinc
12-05-2007 08:51:17
[quote:b5e048f71a]Hi Randy, Last spring I was in the same boat you are in, replacing every bearing in the H rear and tranny! I got all my bearings at a place called Coldwell in Terre Haute Indiana and saved a TON! Dealer is so high if you call them for prices you will feel a lot better about replacing all the bearings from Coldwell! CaseIH wanted $198 for the outside wheel bearing and coldwell had them for about $62 and those were the most expensive bearings to replace! They can cross refference all the numbers except the pilot bearing (bower bearing)on the input shaft which is getting hard to find they said but they had one for me in one day. They also had all the seals CHEAP! They handle NTN bearings which are about the best there is. You can find thier number in the yellow pages and I would bet they can ship them to you. Good guys who know what they are doing! When you replace the "maxload" bearings be sure to keep the "notches" turned to a side where the balls can"t come back into the gear case if they wear agian or get a shock load. That will save the case from getting blown out. When I got mine done, you could feel the difference in how smooth it rolled and operated! It is amazing how much horsepower is eaten up by wore out bearings. My H went from a "cuss target" to my favorite tractor! Good luck on your project![/quote:b5e048f71a]
Do you have a part number for that pilot bearing? And a pic would be nice also. The bearing guy said there are several configurations of that bearing to choose from.
The old bearing is MU1205 and the replacement has a better cage to hold the bearings according to my neighbor.
Randy
neblinc
12-06-2007 09:50:41
 Re: Here is the number! in reply to neblinc, 12-05-2007 08:51:17
Thanks Bob!!
Randy
Bob Kerr
12-06-2007 08:37:54
BU-1205 there is no name on the box, but it fit right in. Besure to check the wear pattern inside the input shaft hole. Mine was deep and I had to find a better gear. Replace the gear on the lower shaft it rides on to keep the whine down to a min. Beware of the after market gears, they SCREAM when running for some reason. You could hear mine loud and clear 2 blocks away! I sent them back and found better used ones.
Bob Kerr
12-05-2007 19:23:56
 Re: Bob Kerr in reply to neblinc, 12-05-2007 08:51:17
Hi Randy, I will have to get out to the barn in the morning and look for that box. Mother nature turns off the "lights" in the barn every evening for me. I wish my girlfriend would do that! The house is lit up like Las Vegas every night :(
neblinc
12-05-2007 12:22:08
awww, I wanted Tractor Times third party image
Thanks Mike
Mike CA
12-05-2007 12:04:11
Way off topic, but I sent that cover plate to you, Randy. Give it a while to get there.
Oh, I packed it with a couple issues of Navy Times... so you could have something new to read. third party image
