Super A rear light
robertb
12-05-2007 16:39:10
I have a 1948 Super A my qestion is which rear light should I mount on the rear the book shows one light with a red light mounted on top. The other is a light with a red bulb mounted inside behind the clear lens. thanks for any help.
Dave H (MI)
12-06-2007 12:05:21
 Re: Super A rear light in reply to robertb, 12-05-2007 16:39:10
If Gene says either one is OK then I would go with the switch light. Nice big round red circle should you be out on a dark road at night. The other light is not made in reproduction to the best of my knowledge (at least not to original specs) so the originals could be scarce and pricey.
SuperA-Tx
12-05-2007 18:14:54
I have a 1948 SA I restored. It has/had the same light on the rear as the front which is the clear tear drop light. I had to replace the rear one because it was so dented up I didnt think I could fix it. I cant remember if I got it from here at YT or from OEM but it was a perfect match for the front. I think now I got it from OEM because they had the 12 volt which mine had been converted too.
The others you mentioned might work but I have never tried them.
Pretty tractor when they are all fixed up. Good luck with yours.
gene bender
12-05-2007 17:16:41
Either one would be o.k.
