Archive problem
GeneMO
12-06-2007 10:57:23
I know folks get tired of answering questions over and over, so I am trying to search the archives first. I was looking for access to a parts manual for a Super H. When I ask it to search for "parts manual" and specify the farmall forum, it always switches to a search of the entire site, and all I get are articles on White tractors. what am I doing wrong?
Thanks, Gene
PS shoulder surgery went OK. Left arm is in a sling but pain meds are making it tolerable.
GordoSD
12-06-2007 13:08:40
 Re: Archive problem in reply to GeneMO, 12-06-2007 10:57:23
I dunno, worked for me, got 4 hits. First select 'archives' from the message list page. You should get a page full of numbers. Look at the heading 'keyword search' click there. DO NOT put anything in the search box in upperright hand corner. Now you should have a screen that allows entry of keyword AND 'which forums do you want to search' Gordo
DCW
12-06-2007 12:29:13
I found the original reprints from Binder Books to be very good and reasonably priced.www.binderbooks.com.
GeneMO
12-06-2007 15:52:46
 Re: Archive problem in reply to DCW, 12-06-2007 12:29:13
i just ordered about $60.00 of books from binder and was trying to protect the bank account. i bought the clutch service manual, the clutch adjustment manual and finally the H engine and chassis service manual. i have an original H owners manual and the IT manual. thought i had better make do for now. dang its hard to type one handed! Bib overalls make a good sling though. I will search a little more and look at the case/IH site
Thanks so much, gene
Retcol
12-06-2007 12:18:59
I never have much luck when I try the archives. No matter how much I attempt to be specific I always end up with a bunch of unrelated trash
Janicholson
12-06-2007 11:02:00
I am relieved that you are operational. May the rag I suggested be tied to a bench be found useful. Go to caseih.com set it for USA, Select parts and service, Select begin your parts search here,
enter farmall in the box
Select the tractor and then the parts area you need. JimN
