F-20 head cracks
Scott Rukke
12-07-2007 17:41:27
Left my F-20 head at the local machine shop for a valve job and they mag fluxed it and found 2 cracks on the block side and 1 on the valve train side. Now the 2 on the block side are small and not near the combustion changer so I am sure they will be OK. I have seen several comments on here that cracks are common in the water jacket areas of the heads and don't really pose any issues. The one on the valve train side is approx. 2 inches long and it's hard to tell how deep it is. I planned on cutting a groove and brazing it closed. I am a former welder and see no issues with a repair by brazing.
Anyone had any experience with these small hairline cracks in the F heads?
James Williams
12-08-2007 03:41:56
 Re: F-20 head cracks in reply to Scott Rukke, 12-07-2007 17:41:27
Scott,A lot of cracks has been repaired,mostly by cold welding,{stiching}a head should be easy to find,Im sure cowman has a dozen or so
jimmy
Nebraska Cowman
12-08-2007 03:38:00
I think most of them have cracks of some sort. I probably wouldn't worry about it. Use you own judgement on welding as heating it could cause more harm than good.
