DANGIT!!
Mike CA
12-07-2007 18:16:22
So I brought my salvaged water temp gauge in to check it. I boiled some water and stuck the gauge in to read. But the way it was twisted the gauge was upside down as I read it, so I tried to gently bend it around. *POP* sssss ssss A small hole popped open in the line and water/steam squirted out.
Ruined, right? third party image
Mike CA
12-09-2007 10:42:49
 Re: DANGIT!! in reply to Mike CA, 12-07-2007 18:16:22
GordoSD said: Mike, Look at all the great tractor restorations and you will see that all the instruments have been replaced with shiny bright NEW items. New wiring, new brass nuts, every detail clean and new looking. There's no way to get around buying a ton of new parts for that H.
But...you don't have to do it all before you get it running. I assume you have the radiator all repaired and replaced and are ready to fire it up?
Just put the plug in and don't worry for now. I have never seen an H with a good stat, clean radiator and good pump overheat.
Put a new temp gauge on your Christmas list.All of us on this list have one thing on our list, that's a picture of you driving the H!
Gordo
I just got the radiator off yesterday. I'm taking it to the shop this week for an estimate.
Yes, I'll be buying all new gauges eventually, but I was led to believe that it would be phenomenally stupid to not have a temp gauge on a tractor engine I know nothing about. So, I was going to make due with a temporary fill-in.
I wish I could fulfill that Christmas wish, but it's not going to happen before then. But progress is progress. At least it's not sitting idle.
Andy Motteberg
12-09-2007 10:42:33
Most likely ruined. You can almost never re use a temp gauge. Better to just buy a new one.
Andy.
GordoSD
12-09-2007 08:20:18
Mike, Look at all the great tractor restorations and you will see that all the instruments have been replaced with shiny bright NEW items. New wiring, new brass nuts, every detail clean and new looking. There's no way to get around buying a ton of new parts for that H. But...you don't have to do it all before you get it running. I assume you have the radiator all repaired and replaced and are ready to fire it up? Just put the plug in and don't worry for now. I have never seen an H with a good stat, clean radiator and good pump overheat. Put a new temp gauge on your Christmas list.All of us on this list have one thing on our list, that's a picture of you driving the H!
Gordo
Janicholson
12-09-2007 06:04:13
The fluid in the gauge is not water, it is a compound designed to have an expansion rate that is consistent when in the range of from above freezing, to 250 degrees F. I think Keith has the answer if you want it. A replacement gauge was in your future anyway if I recall, just use a candy thermometer in the radiator neck in the mean time, The bulb will still block off the hole in the engine, just use some side cuts to snip the remaining capillary tube. JimN
Keith-OR
12-08-2007 00:10:52
 Re: DANGIT!! in reply to Chuck46, 12-07-2007 18:16:22
Keith-OR said: (quoted from post at 00:49:49 12/08/07)
Hey Mike, ya might want to read this article on repairing machanical temp gage. I found this last year doing a search for something else but related. Quite interesting, I think one of these days I'm going to give it a try. One has nothing to loose but time.HTH
Keith & Shawn(Special Olympic Champion)
would help if I would include the website
http://www.ply33.com/Repair/tempgauge
Keith-OR
12-07-2007 23:49:49
 Re: DANGIT!! in reply to Canadian Ken, 12-07-2007 18:16:22
Mike CA said: (quoted from post at 19:16:22 12/07/07) So I brought my salvaged water temp gauge in to check it. I boiled some water and stuck the gauge in to read. But the way it was twisted the gauge was upside down as I read it, so I tried to gently bend it around. *POP* sssss ssss A small hole popped open in the line and water/steam squirted out.
Ruined, right? :?
tractorsam
12-07-2007 18:38:59
I think those old temp gauges work kind of like old tractor electrics - once you let the smoke out it's kaput. Maybe someone has a fix. tractorsam
