485 HYDRAULIC PROBLEM
MARK R
12-09-2007 13:21:52
GEORGE IN KY,DID YOU GET MY EMAIL,I CAN T TELL IF IT WENT THRU?THANKS,MARK
Fromjb2
12-09-2007 16:55:12
 Re: 485 HYDRAULIC PROBLEM in reply to MARK R, 12-09-2007 13:21:52
Hi Mark, I kept a file of problems & solutions of the 84 series tractors from replies from Bernard le mécano. Reason, my brother has 4 of these tractors and someday he is going to have some of these problems. BE CAREFULL when troubleshooting high pressure hydraulic problems.
See below for possible hydraulic solution.
JimB
Hi, may be the unload valve is stuck. Check with engine running, raise the hitch and pull the remote lever at same time . If the hitch raises, you have dirt in the unload valve. This valve is under the seat. You remove the large plug for access. One trick, loosen the large plug, unload valve, 2 turns and start the engine, the hitch should raise if the valve is stuck. It will have a small hole in the valve and just blow the dirt out with compressed air. Replace the O rings.
Bernard le mécano Québec Canada
georgeky
12-09-2007 13:41:35
Yea, I got and replied to it. Maybe it went off into outer space or something. I haven't found my service manual for those. You can go to CaseIH.com and click on search for parts. When the new page comes up cilck on begin search for parts here in the lower right corner. The type in 485 in the search box. A complete schematic for those draft sensing parts is there. I will ask my buddy the IH man tomorrow about your problem as he will know more than I about it.
MARK R
12-09-2007 14:13:42
 Re: 485 HYDRAULIC PROBLEM in reply to georgeky, 12-09-2007 13:41:35
GEORGE,I COULD NOT EVEN TELL IF THE EMAIL SENT TO YOU FOR SURE;BUT YOURS DID NOT COME BACK TO ME.THANKS FOR YOUR TIME AND TROUBLE,MARK
