need HP RPM
JimRick
12-09-2007 13:41:57
Hi,
my friend have a McComick Farmall 300 Serial number 22074 SJ and we are looking for the HP & RPM of the motor because is want to put a snow blower.
answer me at rickmichaud@hotmail.com
thank you for all your help
Hugh MacKay
12-10-2007 02:31:14
 Re: need HP RPM in reply to JimRick, 12-09-2007 13:41:57
Jim: one problem with snowblowers on Farmall tractors is, they are to high speed in transmission, even in low on TA they are still too fast. They were not designed as a snow blower tractor. A Farmall 300 will move more snow with an 8' blade then it will with a blower.
Wardner
12-10-2007 14:31:11
 Re: need HP RPM in reply to Hugh MacKay, 12-10-2007 02:31:14
He could fix the TA, install gears (mainshaft and bevel along with first gear) from a 460 or 504, fit smaller tires and wheels, and it would still be too fast and underpowered. He needs a hydro.
Now, if he had a 400, he could do all of the above using 560 components and 660 planetaries and he might have something. I am not going to do the math, but I bet top speed in fifth direct will be no faster than 8 mph. Creeper gear at rated rpm might be 1/2 mph.
I have done the above, less planetaries, on a SMTA and have a top speed of 11 mph.
JimRick
12-10-2007 03:18:10
Hi,
my friend already put one snowblower on it but the snow go only around 2 feet away.
we will try to put a reductor to increase the peed.
thank you.
r4etired
12-09-2007 17:25:51
A 7ft double auger,2 stage will over load a 656, you have to slip the clutch. I sold my blower as a 656 was my biggest tractor. If you are thinking 300, You had better start blowing when it starts snowing. My 2 cents worth.
JimRick
12-10-2007 03:20:06
 Re: need HP RPM in reply to r4etired, 12-09-2007 17:25:51
hi,
i'm not very good in english but what you say the 300 maybe you going to blow the clutch? but if it put a speed increase(reductor) on it to have more RPM..??
thanks
Pat-CT
12-09-2007 15:13:15
itll run a resonably sized snowblwer with no problems
CNKS
12-09-2007 14:30:51
You want the PTO rpm, it is 540. In order to use a snowblower, the TA has to work. Ground speed in 1st is too fast without the TA.
JimRick
12-10-2007 03:21:15
 Re: need HP RPM in reply to CNKS, 12-09-2007 14:30:51
TA?
ejr-IA
12-09-2007 14:01:52
The engine RPM is 1750 and the HP is 35 on the drawbar and around 39 on the PTO.
JimRick
12-10-2007 03:05:52
 Re: need HP RPM in reply to ejr-IA, 12-09-2007 14:01:52
hi,
ok, you say 1750 RPM & 35 Horse Power
thank you for the fast answer..
